Nuove HiFiMan all'orizzonte Empty Nuove HiFiMan all'orizzonte
14/8/2018, 11:11
Copio-incollo da Head-Fi:
"For Immediate Release
Hong Kong High End Audio Visual Show 2018, August 10 – 12, Hong Kong Convention and Exhibition Centre
New HE6se Updates HiFiMan’s Beloved Headphone with New Headband and Angled Connectors
HE6se Adds Increased Comfort and an Aesthetic Upgrade to a Legendary Favorite
ORLANDO, FL, August 11, 2018 – HiFiMan, the leader in high fidelity personal audio, is using the occasion of the Hong Kong High End Audio Visual Show to unveil the HE6se headphone, an update of the original HE6, considered to be one of the audio market’s most natural and transparent headphones.
“For many music lovers, the HE6 was their introduction to true high-performance audio from a headphone, and it remains one of our most successful products to date” said Dr. Fang Bian, Founder and CEO, HiFiMan. “But I can’t help looking at our biggest sellers without thinking about what we can do a little different that will make them noticeably better.”
Epitomizing Dr. Bian’s commitment to constantly looking for ways to improve on his most esteemed products, the new HE6se (SRP: $1,799) features revisions that further increase comfort and usability while staying true to the outstanding sonics of the original model.
For starters, a newly designed headband is lighter and more adjustable for increased comfort and a natural fit for hours of uninterrupted listening.
As with all new HiFiMan products, the HE6se features 3.5mm headphone connectors that are angled at 10°, thereby lessening the pressure points associated with straight-angled connectors. These pressure points sometimes stress the connection, but the new design ensures a solid, reliable, and long lasting link between the headphone and the cable.
In addition to updating the connector and headband, HiFiMan elevated the aesthetic appeal of the original by adding a new gun metal gray satin finish that is elegant and visually appealing.
The new HE6se maintains the original model’s exceptional sonic characteristics, in particular its wide, natural soundstage that puts the listener in the best seat in the house. Imaging and depth are neutral, staying true to the artist’s and producer’s intended sound.
Like many of the finest full-size loudspeakers, the HE6se headphone requires a powerful amplifier to drive it. To this end, HiFiMan includes its HE6 adapter with the new model, making it easy to connect the HE6se to nearly any currently available power amplifier.
For more information on the HiFiMan HE6SE, visit: www.hifiman.com.
HE6se Product Specifications
· Weight: 502 grams/17.7 ounces
· Frequency response: 8Hz-65kHz
· Sensitivity: 83.5dB
· Impedance: 50 Ohm
Accessories included with the HE6se
· HE Adapter for driving the HE6se with a full-size power amplifier
· OCC (single crystal copper) 4-pin XLR cable (2 meters/6 feet)
· OCC XLR to 6.5mm headphone plug adapter (1 meter/3 feet)
· Headphone cable connector
· Spare earpad"
E una nuova HE1000se:
"Scheduled to ship in September at a suggested retail price of $3,499, the new HE1000se [Special Edition] is the third version of HiFiMan’s distinguished HE1000, featuring increased sensitivity for superior performance when paired with every imaginable source, from audiophile-grade source components to high-resolution digital audio players -- even tablets and smartphones."
"By increasing the sensitivity from 91 to 96 dB (decibels), HiFiMan’s HE1000se is easier to drive from any source, with a greater sense of presence and realism, especially when paired with high-performance electronics.
New to the HE1000se are neodymium magnets that increase efficiency and lower distortion for true purity of sound. Neodymium, widely recognized for providing incomparable magnetic strength in a compact size, providing consistently exceptional output that is equal to larger and heavier ferrite magnets. With neodymium, the new model’s driver is faster and more dynamic, presenting every sonic detail for a more compelling performance."
A quanto pare, "SE" sta per "Special Edition".
Per la HE6 si tratta della seconda iterazione, mentre per la HE1000, dopo la beffa della V2, questa è la terza revisione in due anni e mezzo.
I prezzi sono semplicemente da spennapolli, soprattutto per la HE6se: una cuffia uguale alla precedente, con le stesse identiche specifiche, per la quale quindi non c'è stata alcuna forma di ricerca e sviluppo e per la quale i costi dovrebbero essere stati ammortizzati da tempo, che costa più di prima. Il nuovo headband e i nuovi connettori non possono giustificare più di 500 dollari di aumento. All'epoca una HE6 nuova si prendeva per poco più di 1000 dollari, ora ce ne vogliono, al lancio, 1800. E' vero che poi il prezzo scenderà, ma questa special edition dovrebbe costare di meno, non di più.
Per la HE1000se il discorso è un po' diverso in quanto i trasduttori sono stati effettivamente modificati per ottenere una sensibilità superiore di 5 dB. E questo però impone tutta una serie di interrogativi: questa nuova versione costa di più dell'originale, e avendo driver nuovi potrebbe non essere così vicina alla precedente come sonorità. Il fatto che abbiano cambiato la struttura dei magneti ci fa sospettare qualcosa di completamente diverso. E non è detto che sia per forza un miglioramento. Di solito, l'aumento della sensibilità si fa sempre a scapito di qualche altra caratteristica, nonostante le cose scritte sul depliant.
Quindi, ricapitolando: avremo una nuova HE6 uguale alla precedente che però costa di più; una nuova HE1000 che suona più forte, ad un costo di 500 dollari per 5 dB, ovvero 100 dollari al dB.
Nel frattempo, chi dovesse cambiare i pads della sua ormai vecchia e decrepita HE1000 versione 2015 deve mettere quelli per la V2, in quanto i cinesi non ritengono importante mantenere un minimo di assistenza per i loro prodotti. La HE1000 2015 con i pads della V2 non suona allo stesso modo (suona peggio) e quindi Mr. Fang dovrebbe spiegarci perchè oggi dovrei acquistare una HE1000 "special edition" con la consapevolezza che dopo magari un anno potrebbe uscire una HE1000 "special edition V2" e poi forse una "supercazzola edition" e perdere la speranza di ottenere un ricambio dei pads originali.
Oppure di dovermi mettere a cercare su ebay una copia cinese. La copia cinese di un prodotto cinese.
O forse è l'originale?
New Velvet Velour Ear Pads Cushion For HE1000
Se non ci fosse da piangere, ci sarebbe da ridere.
Nuove HiFiMan all'orizzonte Empty Re: Nuove HiFiMan all'orizzonte
14/8/2018, 14:57
Ma sì, lasciamo HiFiMan al suo percorso atto al depauperamento dell'appassionato...
Occupiamoci delle cuffie possibili...
14/8/2018, 15:10
Io tengo la mia vecchia 1000 e vivo felice...
2slow4u
2slow4u
Data d'iscrizione : 25.07.14
14/8/2018, 22:40
Credo che ormai HFM campi per lo piu' sui "polli", vedo molti "non polli" allontanarsi dal marchio da un po' di tempo a questa parte...
15/8/2018, 10:30
cicciopasticcio ha scritto:Credo che ormai HFM campi per lo piu' sui "polli", vedo molti "non polli" allontanarsi dal marchio da un po' di tempo a questa parte...
Un marchio che ha fatto anche cose buone, ma che non sta capitalizzando l'esperienza fatta in questi anni, puntando tutto sulle debolezze e sulla pazienza degli appassionati.
17/8/2018, 16:25
Nuove HiFiMan all'orizzonte 43373173114_9db44ba3a4_d
Liberamente copiata da Head-Fi.
17/8/2018, 18:53
laugh
