- armonia.sonoramela
Data d'iscrizione : 08.05.14
Gustard ES9018 DAC-X10 XMOS Asynchronous USB
>>4 Inputs:
Coaxial, Optical, AES/EBU (well support up to 24Bit/192Khz)
USB (PCM support up to 32Bit/384Khz) , usb recommend ASIO output, it is better than WASAPI
sample rate
Coaxial:16-32bit /44.1、48、88.2、96、176.4、192 kHz
optical: 16-32bit /44.1、48、88.2、96、176.4、192 kHz
AES/EBU:16-32bit /44.1、48、88.2、96、176.4、192 kHz
USB: 16-32bit / 44.1、48、88.2、96、176.4、192、352.8、384 kHz
DSDx64(2.8224MHz)、DSDx128(5.6448MHz)
>>Analog Output:
RCA Output :2.5 Vrms @0dBFS
XLR Output :5 Vrms @0dBFS
Frequency :20-20K Hz +/-0.15dB
>>Dimension: 190 x 70 x 313 mm (W x H x D)
>>Package weight: about 4KG
Features:
>>DAC IC: ES9018 (ESS Technology Sabre Reference 32bit ES9018 DAC chip)
>>USB IC: XMOS (Asynchronous USB2.0, best USB receiver chip)
>>CPLD program: microcontroller the DAC, volume can be control
>>LCD display&fuction switch: input singal selection,filtering selection,sample rate
>>Digital Input: balanced Spdif AES/EBU port, RCA, Toslink Optical input and USB
>>Analog Output: balanced analog output via XLR port, single ended output via RCA port.
>>4 Inputs:
sample rate
>>Analog Output:
Features:
quanto costa?
mi sembra avere specifiche simili alla sezione dac dell'oppo ha-1
Ciao pierpaolo
costa circa 380 euro
grazie
grazie
Dentro in versie moddata:
https://dl.dropboxusercontent.com/u/44975324/20140312_185923.jpg
Bellino...
bello
Sembra il Wyred 4 Sound DAC
Solo da fuori
