Pagina 1 di 2 • 1, 2
Tutto quello che serve per costruirsi un Lightning
Lun 19 Nov 2012 - 18:09
Schemi elettrici, part-list, pcb, cabinet... trovate tutto qui.
SUPPLY BOARD
Lun 19 Nov 2012 - 23:02
SCHEMA ELETTRICO
PIANO DI MONTAGGIO
PCB
(200 x 80 mm, HMAX 33.5)
PART LIST
N. 3 ponti rettificatori B80C1500B (Distrelec: 602281)
B1 2KBB 2KBB rectifier 1
B2 2KBB 2KBB rectifier 1
B3 2KBB 2KBB rectifier 1
N. 2 condensatori elettrolitici 4700u 50VDC passo 10 diametro 35 (Distrelec: 818844)
C1 4700u CPOL-EUE10-35 EB35D resistor 1
C2 4700u CPOL-EUE10-35 EB35D resistor 1
N. 2 condensatori elettrolitici 4700u 25VDC passo 7.5 diametro 16 (Distrelec: 802589)
C5 4700u CPOL-EUE7.5-16 E7,5-16 resistor 1
C6 4700u CPOL-EUE7.5-16 E7,5-16 resistor 1
N. 2 condensatori elettrolitici 470u 200VDC passo 10 diametro 30 (Distrelec: 800161)
C3 470u CPOL-EUE10-30 EB30D resistor 1
C4 470u CPOL-EUE10-30 EB30D resistor 1
N. 6 condensatori ceramici C0G 150p 200VDC passo 5 24x44 (Distrelec: 830207)
C7 150p C-EU050-024X044 C050-024X044 resistor 1
C8 150p C-EU050-024X044 C050-024X044 resistor 1
C9 150p C-EU050-024X044 C050-024X044 resistor 1
C10 150p C-EU050-024X044 C050-024X044 resistor 1
C11 150p C-EU050-024X044 C050-024X044 resistor 1
C12 150p C-EU050-024X044 C050-024X044 resistor 1
N. 1 condensatore ceramico X7R 1u 50VDC passo 5 24x44 (Distrelec: 833089)
C14 1u C-EU050-024X044 C050-024X044 resistor 1
N. 4 condensatori ceramici 10n 1KV passo 5 24x44 (Distrelec: 831641)
C15 10n C-EU050-024X044 C050-024X044 resistor 1
C16 10n C-EU050-024X044 C050-024X044 resistor 1
C17 10n C-EU050-024X044 C050-024X044 resistor 1
C18 10n C-EU050-024X044 C050-024X044 resistor 1
N. 4 condensatori film poliestere 100n 160VAC passo 5 55x75 (Distrelec: 822149)
C13 100n C-EU050-055X075 C050-055X075 resistor 1
C19 100n C-EU050-055X075 C050-055X075 resistor 1
C20 100n C-EU050-055X075 C050-055X075 resistor 1
C21 100n C-EU050-055X075 C050-055X075 resistor 1
N. 1 condensatore elettrolitico 10u 25VDC passo 2.5 diametro 6 (Distrelec: 802959)
C40 10u CPOL-EUE2.5-6 E2,5-6 resistor 1
NOTA: Il condensatore C40 deve essere presente solo nel caso si utilizzino i pulsanti per la selezione degli ingressi. Se si usa un commutatore, tale condensatore va eliminato.
N. 1 diodo 1N4004 (Distrelec: 600096)
D1 1N4004 1N4004 P1-10 diode 1
D2 (sostituire con un ponticello)
N. 4 diodi BYV26C 1A 600V (Distrelec: 601814)
D3 BYV26C BYV27 SOD57-10 diode 1
D4 BYV26C BYV27 SOD57-10 diode 1
D5 BYV26C BYV27 SOD57-10 diode 1
D6 BYV26C BYV27 SOD57-10 diode 1
N. 9 diodi 1N4148 (Distrelec: 603016)
D13 4148 DIODE-D-5 D-5 diode 1
D16 4148 DIODE-D-5 D-5 diode 1
D17 4148 DIODE-D-5 D-5 diode 1
D19 4148 DIODE-D-5 D-5 diode 1
D20 4148 DIODE-D-5 D-5 diode 1
D21 4148 DIODE-D-5 D-5 diode 1
D22 4148 DIODE-D-5 D-5 diode 1
D23 4148 DIODE-D-5 D-5 diode 1
D24 4148 DIODE-D-5 D-5 diode 1
N. 2 circuiti integrati CMOS HEF4013 (Distrelec: 648788)
IC1 HEF4013 4013N DIL14 40xx 1
IC2 HEF4013 4013N DIL14 40xx 1
N. 2 zoccoletti DIL-14 (Distrelec: 650555)
N. 1 circuito integrato 78S12 12V 2A (Distrelec: 645232)
IC3 78S12 78XXL 78XXL v-reg 1
JP1 (non usato) JP1E JP1 jumper 1
NOTA: JP1 non serve in quanto avendo modificato il valore di R4 ora l'alimentazione dei filamenti va bene sia per la 6N1P che per la 6922 senza la necessità di selezionare con il jumper.
N. 3 rele' 12V FUJITSU A12WK (Distrelec: 400022)
K1 A-12-WK G6H2-100 G6H2-100 relay 1
K2 A-12-WK G6H2-100 G6H2-100 relay 1
K3 A-12-WK G6H2-100 G6H2-100 relay 1
N. 3 transistor darlington NPN BC517 (Distrelec: 605018)
Q10 BC517 -NPN-TO92-CBE TO92-CBE transistor-neu-to92 1
Q11 BC517 -NPN-TO92-CBE TO92-CBE transistor-neu-to92 1
Q13 BC517 -NPN-TO92-CBE TO92-CBE transistor-neu-to92 1
N. 9 resistenze 0.4W 0204 passo 5 2.2Kohm (Distrelec: 714318)
R1 2K2 R-EU_0204/5 0204/5 resistor 1
R2 2K2 R-EU_0204/5 0204/5 resistor 1
R3 2K2 R-EU_0204/5 0204/5 resistor 1
R5 2K2 R-EU_0204/5 0204/5 resistor 1
R8 2K2 R-EU_0204/5 0204/5 resistor 1
R9 2K2 R-EU_0204/5 0204/5 resistor 1
R10 2K2 R-EU_0204/5 0204/5 resistor 1
R11 2K2 R-EU_0204/5 0204/5 resistor 1
R12 2K2 R-EU_0204/5 0204/5 resistor 1
N. 1 resistenza a filo 3W 0411 passo 15 3.3ohm (Distrelec: 721939)
R4 3R3 3W R-EU_0411/15 0411/15 resistor 1
N. 1 resistenza a filo 1W 0309 passo 12 47ohm (Distrelec: 723528)
R6 47 1W R-EU_0309/12 0309/12 resistor 1
N. 1 resistenza 1W 0411 passo 15 47Kohm (Distrelec: 712072)
R7 47K 1W R-EU_0411/15 0411/15 resistor 1
N. 2 resistenze 0.4W 0204 passo 5 8.2Kohm (Distrelec: 714332)
R13 8K2 R-EU_0204/5 0204/5 resistor 1
R14 8K2 R-EU_0204/5 0204/5 resistor 1
N. 6 resistenze 0.4W 0204 passo 5 47Kohm (Distrelec: 714351)
R34 47K R-EU_0204/5 0204/5 resistor 1
R35 47K R-EU_0204/5 0204/5 resistor 1
R37 47K R-EU_0204/5 0204/5 resistor 1
R69 47K R-EU_0204/5 0204/5 resistor 1
R70 47K R-EU_0204/5 0204/5 resistor 1
R71 47K R-EU_0204/5 0204/5 resistor 1
N. 3 resistenze 0.4W 0204 passo 5 22Kohm (Distrelec: 714343)
R36 22K R-EU_0204/5 0204/5 resistor 1
R72 22K R-EU_0204/5 0204/5 resistor 1
R74 22K R-EU_0204/5 0204/5 resistor 1
N. 3 resistenze 0.4W 0204 passo 5 180ohm (Distrelec: 714292)
R40 180 R-EU_0204/5 0204/5 resistor 1
R73 180 R-EU_0204/5 0204/5 resistor 1
R75 180 R-EU_0204/5 0204/5 resistor 1
N. 11 connettori molex KK 1x2 (Distrelec: 114620)
X1 22-23-2021 22-23-2021 22-23-2021 con-molex 1
X2 22-23-2021 22-23-2021 22-23-2021 con-molex 1
X3 22-23-2021 22-23-2021 22-23-2021 con-molex 1
X4 22-23-2021 22-23-2021 22-23-2021 con-molex 1
X5 22-23-2021 22-23-2021 22-23-2021 con-molex 1
X6 22-23-2021 22-23-2021 22-23-2021 con-molex 1
X12 X12 22-23-2021 22-23-2021 con-molex 1
X13 X13 22-23-2021 22-23-2021 con-molex 1
X14 X14 22-23-2021 22-23-2021 con-molex 1
X16 X16 22-23-2021 22-23-2021 con-molex 1
X17 X17 22-23-2021 22-23-2021 con-molex 1
N. 11 prese molex KK 1x2 (Distrelec: 114600)
N. 1 connettore molex KK 1x4 (Distrelec: 114624)
X7 X7 22-23-2041 22-23-2041 con-molex 1
N. 1 presa molex KK 1x4 (Distrelec: 114604)
N. 5 connettori molex KK 1x3 (Distrelec: 114622)
X8 X8 22-23-2031 22-23-2031 con-molex 1
X9 X9 22-23-2031 22-23-2031 con-molex 1
X10 X10 22-23-2031 22-23-2031 con-molex 1
X11 X11 22-23-2031 22-23-2031 con-molex 1
X18 X18 22-23-2031 22-23-2031 con-molex 1
N. 5 prese molex KK 1x3 (Distrelec: 114602)
N. 41 contatti molex KK (Distrelec: 127661)
N. 4 distanziali 5mm poliammide (Distrelec: 341047)
N. 4 viti M3 16mm torx (Distrelec: 343196)
N. 5 dadi esagonali M3 (Distrelec: 348280)
N. 1 dissipatore Fischer SK 09/37,5/SA-220 10°K/W (Distrelec: 650020)
N. 1 vite M3 10mm torx testa cilindrica (Distrelec: 343194)
N. 1 rondella elastica M3 acciaio (Distrelec: 348268)
TOTALE DISTRELEC, IVA E SPEDIZIONE COMPRESI: 92.52 Euro
N. 1 trasformatore toroidale con primario 220V, e i seguenti avvolgimenti secondari:
- 115 VAC, 57.5 VA
- 15 VAC, 30 VA
- 30 VAC, 30 VA
- 30 VAC, 30 VA
Il costo del trasformatore varia a seconda del numero dei pezzi, ma siamo intorno ai 30 Euro.
Il costo della pcb varia a seconda del numero dei pezzi, ma si aggira intorno ai 25 Euro.
Il costo totale dei componenti per la supply board, compresi pcb e toroidale, è quindi di circa 148 Euro.
PIANO DI MONTAGGIO
PCB
PART LIST
- 115 VAC, 57.5 VA
- 15 VAC, 30 VA
- 30 VAC, 30 VA
- 30 VAC, 30 VA
PREAMP BOARD
Dom 25 Nov 2012 - 17:08
SCHEMA ELETTRICO
PIANO DI MONTAGGIO - TOP
PIANO DI MONTAGGIO - BOTTOM
PCB
PART LIST
N. 4 condensatori elettrolitici 470uF 10V passo 2.5 diametro 6 (Distrelec: 802413)
C1 470u CPOL-EUE2.5-7 E2,5-7 resistor 1
C2 470u CPOL-EUE2.5-7 E2,5-7 resistor 1
C5 470u CPOL-EUE2.5-7 E2,5-7 resistor 1
C6 470u CPOL-EUE2.5-7 E2,5-7 resistor 1
N. 2 condensatori elettrolitici 220uF 200V passo 10 diametro 22 altezza 25 (Distrelec: 818890)
C11 220u CPOL-EUE10-22.5 EB22,5D resistor 1
C12 220u CPOL-EUE10-22.5 EB22,5D resistor 1
NOTA: chi monta la scheda con le valvole in verticale in un cabinet slim da 40 mm deve usare questi:
N. 2 condensatori elettrolitici 220uF 200V passo 10 diametro 25 altezza 20 (RS: 739-5759)
C11 220u CPOL-EUE10-25 EB25D resistor 1
C12 220u CPOL-EUE10-25 EB25D resistor 1
N. 2 condensatori polipropilene 68nF 400VDC passo 5 (Distrelec: 828287)
C3 68n C-EU050-055X075 C050-055X075 resistor 1
C7 68n C-EU050-055X075 C050-055X075 resistor 1
N. 2 condensatori polipropilene 2.2uF 250VDC passo 22.5 (Distrelec: 828254)
C4 2u2 C-EU225-113X268 C225-113X268 resistor 1
C8 2u2 C-EU225-113X268 C225-113X268 resistor 1
N. 3 condensatori poliestere 470nF 250VDC passo 10 (Distrelec: 820855)
C9 470n C-EU102-064X133 C102-064X133 resistor 1
C10 470n C-EU102-064X133 C102-064X133 resistor 1
C17 470n C-EU102-064X133 C102-064X133 resistor 1
N. 3 condensatori elettrolitici 4.7 uF 200VDC passo 3.5 diametro 8 (Distrelec: 802647)
C9 4.7u C-EU102-064X133 C102-064X133 resistor 1
C10 4.7u C-EU102-064X133 C102-064X133 resistor 1
C17 4.7u C-EU102-064X133 C102-064X133 resistor 1
N. 2 condensatori ceramici X7R 1uF 50VDC passo 5 (Distrelec: 833089)
C13 1u C-EU050-024X044 C050-024X044 resistor 1
N. 1 condensatore ceramico X7R 100nF 50VDC passo 5 (Distrelec: 833084)
C40 100n C-EU050-024X044 C050-024X044 resistor 1
N. 6 diodi zener 6.8V 500mW (Distrelec: 600775)
D1 6V8 ZENER-DIODEZD-5 ZDIO-5 diode 1
D2 6V8 ZENER-DIODEZD-5 ZDIO-5 diode 1
D3 6V8 ZENER-DIODEZD-5 ZDIO-5 diode 1
D4 6V8 ZENER-DIODEZD-5 ZDIO-5 diode 1
D8 6V8 ZENER-DIODEZD-10 ZDIO-10 diode 1
D6 6V8 ZENER-DIODEZD-10 ZDIO-10 diode 1
N. 2 diodi zener 120V 2W (Distrelec: 600974)
D5 120V ZENER-DIODEZD-10 ZDIO-10 diode 1
D7 120V ZENER-DIODEZD-10 ZDIO-10 diode 1
N. 1 diodo 1N4148 (Distrelec: 603016)
N. 4 LED infrarossi 5mm Vishay TSFF5210 (Distrelec: 632543)
LED1 LED5MMBOTTOM LED5MM led 1
LED2 LED5MMBOTTOM LED5MM led 1
LED3 LED5MMBOTTOM LED5MM led 1
LED4 LED5MMBOTTOM LED5MM led 1
LED5 LED5MMBOTTOM LED5MM led 1
LED6 LED5MMBOTTOM LED5MM led 1
LED7 LED5MMBOTTOM LED5MM led 1
LED8 LED5MMBOTTOM LED5MM led 1
N. 1 circuito integrato HEF4013 DIL14 (Distrelec: 648788)
N. 1 zoccoletto DIL14 (Distrelec: 650555)
N. 2 jumper passo 2.54 (Distrelec: 122350)
JP1 JP1E JP1 jumper 1
JP2 JP1E JP1 jumper 1
JP3 JP1E JP1 jumper 1
JP4 JP1E JP1 jumper 1
N. 4 spine jumper passo 2.54 (Distrelec: 121538)
N. 1 rele' FUJITSU A12W-K (Distrelec: 400022)
K1 A12W-K G6H2-100 G6H2-100 relay 1
N. 2 transistor darlington BC517 (Distrelec: 605018)
Q10 BC517 BC517 TO92-EBC transistor-npn 1
Q11 BC517 BC517 TO92-EBC transistor-non 1
N. 2 resistenze 27K 2W passo 15 (Distrelec: 712211)
R17 27K 2W R-US_0411/15 0411/15 resistor 1
R24 27K 2W R-US_0411/15 0411/15 resistor 1
N. 4 resistenze 22K 1W (Distrelec: 712064)
R1 22K 1W R-US_0411/3V 0411V resistor 1
R5 22K 1W R-US_0411/3V 0411V resistor 1
R11 22K 1W R-US_0411/3V 0411V resistor 1
R15 22K 1W R-US_0411/3V 0411V resistor 1
N. 2 resistenze 180R 1W passo 12 (Distrelec: 712014)
R7 180 1W R-US_0309/12 0309/12 resistor 1
R23 180 1W R-US_0309/12 0309/12 resistor 1
N. 2 resistenze a filo 100R 1W passo 12 (Distrelec: 723529)
R21 100 1W R-US_0309/12 0309/12 resistor 1
R25 100 1W R-US_0309/12 0309/12 resistor 1
N. 1 resistenza 10K passo 5 (Distrelec: 714334)
R2 10K R-US_0204/5 0204/5 resistor 1
N. 5 resistenze 2K2 passo 5 (Distrelec: 714318)
R3 2K2 R-US_0204/5 0204/5 resistor 1
R4 2K2 R-US_0204/5 0204/5 resistor 1
R14 2K2 R-US_0204/5 0204/5 resistor 1
R12 2K2 R-US_0204/5 0204/5 resistor 1
R35 2K2 R-EU_0204/5 0204/5 resistor 1
N. 2 resistenze 100K passo 5 (Distrelec: 714359)
R27 100K R-US_0204/5 0204/5 resistor 1
R28 100K R-US_0204/5 0204/5 resistor 1
N. 2 resistenze 51K passo 5 (Distrelec: 714352)
R6 51K R-US_0204/5 0204/5 resistor 1
R16 51K R-US_0204/5 0204/5 resistor 1
N. 4 resistenze 1K passo 5 (Distrelec: 714310)
R9 1K R-US_0204/5 0204/5 resistor 1
R19 1K R-US_0204/5 0204/5 resistor 1
R29 1K R-US_0204/5 0204/5 resistor 1
R30 1K R-US_0204/5 0204/5 resistor 1
N. 3 resistenze 4K7 passo 5 (Distrelec: 714326)
R10 4K7 R-US_0204/5 0204/5 resistor 1
R20 4K7 R-US_0204/5 0204/5 resistor 1
R34 4K7 R-EU_0204/5 0204/5 resistor 1
N. 2 resistenze 47R passo 5 (Distrelec: 714279)
R22 47 R-US_0204/7 0204/7 resistor 1
R26 47 R-US_0204/7 0204/7 resistor 1
N. 2 resistenze 3K3 passo 5 (Distrelec: 714322)
R31 3K3 R-US_0204/5 0204/5 resistor 1
R32 3K3 R-US_0204/5 0204/5 resistor 1
N. 2 resistenze 22K passo 5 (Distrelec: 714343)
R37 22K R-EU_0204/5 0204/5 resistor 1
N. 1 resistenza 180R passo 5 (Distrelec: 714292)
N. 1 trimmer resistivo 22K (Distrelec: 743468)
R13 22K TRIM_EU-ST10 ST10 pot 1
N. 2 transistor 2SA970 (Distrelec: 605029)
T1 2SA970 2SA970 TO92L transistor 1
T3 2SA970 2SA970 TO92L transistor 1
N. 2 transistor 2SC2240 (RS: 601-1517)
T2 2SC2240 2SC2240 TO92L transistor 1
T4 2SC2240 2SC2240 TO92L transistor 1
N. 2 transistor MJE350 (Distrelec: 612774)
T5 MJE350 TO126-EBC-BOTTOM TO126-BOTTOM transistor-pnp 1
T6 MJE350 TO126-EBC-BOTTOM TO126-BOTTOM transistor-pnp 1
N. 2 transistor MJE340 (Distrelec: 612773)
T7 MJE340 TO126-ECB-BOTTOM TO126-BOTTOM transistor-npn 1
T8 MJE340 TO126-ECB-BOTTOM TO126-BOTTOM transistor-npn 1
N. 2 zoccoli per valvola NOVAL (Distrelec: 620266)
V1 NOVAL ECC88-BOTTOM VT9-PT-BOTTOM Tubes 1
V2 NOVAL ECC88-BOTTOM VT9-PT-BOTTOM Tubes 1
N. 2 valvole 6N1P oppure E88CC oppure 6922 e compatibili
N. 1 connettore molex 4 pin (Distrelec: 114624)
X1 160VDC 22-23-2041 22-23-2041 con-molex 1
N. 1 presa molex 4 pin (Distrelec: 114604)
N. 2 connettori molex 3 pin (Distrelec: 114622)
X2 INPUT 22-23-2031 22-23-2031 con-molex 1
X3 OUTPUT 22-23-2031 22-23-2031 con-molex 1
N. 2 prese molex 3 pin (Distrelec: 114602)
N. 3 connettori molex 2 pin (Distrelec: 114620)
X4 12VDC 22-23-2021 22-23-2021 con-molex 1
X5 GAIN BUTTON 22-23-2021 22-23-2021 con-molex 1
X6 GAIN LED 22-23-2021 22-23-2021 con-molex 1
N. 3 prese molex 2 pin (Distrelec: 114600)
N. 16 contatti molex (Distrelec: 127661)
N. 2 squadrette di montaggio nylon (Distrelec: 340510)
N. 4 viti M3 torx 10mm (Distrelec: 343194)
N. 4 dissipatori AAVID ML33 8.5°C/W (RS: 712-4263)
N. 4 viti M3 torx 12mm (Distrelec: 343195)
N. 4 rondelle acciaio zincato M3 diametro esterno 7 mm (Distrelec: 348259)
N. 4 dadi esagonali M3 (Distrelec: 348280)
N. 4 rondelle elastiche M3 acciaio (Distrelec: 348268)
PCB
PART LIST
NOTA: C3 e C7 vanno sostituiti con dei ponticelli.
NOTA: i condensatori C9, C10 e C17 sono stati sostituiti in quanto quelli da 470 nF con le dimensioni richieste sono difficili da trovare. I nuovi condensatori sono elettrolitici e quindi bisogna rispettare la polarità: il negativo va sempre a massa.
NOTA: LED3, LED7, LED4 e LED5 vanno sostituiti con dei ponticelli.
NOTA: JP2 e JP3 non sono necessari, lasciare libero il posto sulla pcb.
NOTA: queste resistenze vanno montate leggermente distanziate (minimo 5 mm) dalla pcb per evitare che il calore generato si trasferisca direttamente allo stampato.
NOTA: lasciare libero il posto di R6 e R16 sulla pcb.
ATTENZIONE: il piedino 5 di ciascuno zoccolo non va saldato alla pcb, ma va tenuto libero e rivolto verso l'alto in modo da poterci saldare un filo verso il piedino 5 dello zoccolo dell'altra valvola, come indicato nel post in pagina 2 di questo thread sotto il titolo "PREAMP BOARD: modifica al circuito dei filamenti".
POWER BOARD
Gio 29 Nov 2012 - 17:56
SCHEMA ELETTRICO
PCB
PART LIST
N. 2 resistenze 0.4W 100R passo 5 (Distrelec: 714287)
R12 100 R-EU_0204/5 0204/5 resistor
R41 100 R-EU_0204/5 0204/5 resistor
N. 6 resistenze 0.4W 100K passo 5 (Distrelec: 714359)
R25 100K R-EU_0204/5 0204/5 resistor
R27 100K R-EU_0204/5 0204/5 resistor
R54 100K R-EU_0204/5 0204/5 resistor
R55 100K R-EU_0204/5 0204/5 resistor
R66 100K R-EU_0204/5 0204/5 resistor
R63 100K R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.4W 10K passo 5 (Distrelec: 714334)
R13 10K R-EU_0204/5 0204/5 resistor
R42 10K R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.6W 110R passo 10 (Distrelec: 714058)
R38 110 R-EU_0207/10 0207/10 resistor
R39 110 R-EU_0207/10 0207/10 resistor
R72 ponticello
R73 ponticello
N. 4 resistenze 1W 15R passo 10 (Distrelec: 711988)
R2 15 1W R-EU_0207/10 0207/10 resistor
R6 15 1W R-EU_0207/10 0207/10 resistor
R11 15 1W R-EU_0207/10 0207/10 resistor
R21 15 1W R-EU_0207/10 0207/10 resistor
N. 1 resistenza 0.4W 180R passo 5 (Distrelec: 714292)
N. 12 resistenze 0.4W 1K passo 5 (Distrelec: 714310)
R14 1K R-EU_0204/5 0204/5 resistor
R28 1K R-EU_0204/5 0204/5 resistor
R30 1K R-EU_0204/5 0204/5 resistor
R31 1K R-EU_0204/5 0204/5 resistor
R44 1K R-EU_0204/5 0204/5 resistor
R52 1K R-EU_0204/5 0204/5 resistor
R53 1K R-EU_0204/5 0204/5 resistor
R56 1K R-EU_0204/5 0204/5 resistor
R58 1K R-EU_0204/5 0204/5 resistor
R59 1K R-EU_0204/5 0204/5 resistor
R67 1K R-EU_0204/5 0204/5 resistor
R77 1K R-EU_0204/5 0204/5 resistor
N. 4 resistenze 0.4W 1M passo 5 (Distrelec: 714383)
R19 1M R-EU_0204/5 0204/5 resistor
R20 1M R-EU_0204/5 0204/5 resistor
R47 1M R-EU_0204/5 0204/5 resistor
R48 1M R-EU_0204/5 0204/5 resistor
N. 3 resistenze 0.4W 22K passo 5 (Distrelec: 714343)
R69 22K R-EU_0204/5 0204/5 resistor
N. 7 resistenze 0.4W 2K2 passo 5 (Distrelec: 714318)
R3 2K2 R-EU_0204/7 0204/7 resistor
R8 2K2 R-EU_0204/7 0204/7 resistor
R17 2K2 R-EU_0204/7 0204/7 resistor
R24 2K2 R-EU_0204/7 0204/7 resistor
R62 2K2 R-EU_0204/5 0204/5 resistor
R68 2K2 R-EU_0204/5 0204/5 resistor
N. 6 resistenze 0.4W 33R passo 5 (Distrelec: 714275)
R4 33 R-EU_0204/7 0204/7 resistor
R9 33 R-EU_0204/7 0204/7 resistor
R22 33 R-EU_0204/7 0204/7 resistor
R26 33 R-EU_0204/7 0204/7 resistor
R29 33 R-EU_0204/5 0204/5 resistor
R57 33 R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.4W 33K passo 5 (Distrelec: 714347)
R64 33K R-EU_0204/5 0204/5 resistor
R65 33K R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.4W 3K3 passo 5 (Distrelec: 714322)
R16 3K3 R-EU_0204/5 0204/5 resistor
R46 3K3 R-EU_0204/5 0204/5 resistor
N. 4 resistenze 3W 47R passo 12 (Distrelec: 711433)
R1 47 R-EU_0411/12 0411/12 resistor
R5 47 R-EU_0411/12 0411/12 resistor
R7 47 R-EU_0411/12 0411/12 resistor
R10 47 R-EU_0411/12 0411/12 resistor
N. 2 resistenze 0.4W 47R passo 5 (Distrelec: 714279)
R70 47 R-EU_0204/5 0204/5 resistor
R71 47 R-EU_0204/5 0204/5 resistor
NOTA: un capo di queste resistenze (R70 e R71) va collegato ad una piazzola diversa da quella prevista nella loro sede. Leggere attentamente quanto indicato nella pagine successive relativamente a queste resistenze.
N. 3 resistenze 0.4W 470K passo 5 (Distrelec: 714374)
R18 470K R-EU_0204/5 0204/5 resistor
R49 470K R-EU_0204/5 0204/5 resistor
R61 470K R-EU_0204/5 0204/5 resistor
N. 3 resistenze 0.4W 4K7 passo 5 (Distrelec: 714326)
R32 4K7 R-EU_0204/5 0204/5 resistor
R60 4K7 R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.4W 5R6 passo 5 (Distrelec: 714260)
R23 5R6 R-EU_0204/5 0204/5 resistor
R51 5R6 R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.4W 680R passo 5 (Distrelec: 714306)
R43 680 R-EU_0204/5 0204/5 resistor
R50 680 R-EU_0204/5 0204/5 resistor
N. 1 resistenza 0.4W 100R passo 5 (Distrelec: 714287)
R33 100 R-EU_0204/5 0204/5 resistor
N. 2 resistenze 0.4W 2R2 passo 5 (Distrelec: 714255)
R15 2R2 R-EU_0204/5 0204/5 resistor
R45 2R2 R-EU_0204/5 0204/5 resistor
N. 9 condensatori ceramici X7R 100VDC 100n passo 5 (Distrelec: 833104)
C16 100n C-EU050-024X044 C050-024X044 resistor
C29 100n C-EU050-024X044 C050-024X044 resistor
C36 100n C-EU050-024X044 C050-024X044 resistor
C37 100n C-EU050-024X044 C050-024X044 resistor
C38 100n C-EU050-024X044 C050-024X044 resistor
C39 100n C-EU050-024X044 C050-024X044 resistor
C41 100n C-EU050-024X044 C050-024X044 resistor
C42 100n C-EU050-024X044 C050-024X044 resistor
N. 15 condensatori ceramici X7R 50VDC 1u passo 5 (Distrelec: 833089)
C4 1u C-EU050-024X044 C050-024X044 resistor
C6 1u C-EU050-024X044 C050-024X044 resistor
C9 1u C-EU050-025X075 C050-025X075 resistor
C10 1u C-EU050-025X075 C050-025X075 resistor
C15 1u C-EU050-025X075 C050-025X075 resistor
C17 1u C-EU050-025X075 C050-025X075 resistor
C22 1u C-EU050-025X075 C050-025X075 resistor
C26 1u C-EU050-025X075 C050-025X075 resistor
C27 1u C-EU050-025X075 C050-025X075 resistor
C28 1u C-EU050-025X075 C050-025X075 resistor
C30 1u C-EU050-025X075 C050-025X075 resistor
C44 1u C-EU050-025X075 C050-025X075 resistor
C45 1u C-EU050-025X075 C050-025X075 resistor
C46 1u C-EU050-025X075 C050-025X075 resistor
C47 1u C-EU050-025X075 C050-025X075 resistor
N. 6 condensatori poliestere 100VDC 100n passo 5 (Distrelec: 821832)
C12 100n C-EU050-025X075 C050-025X075 resistor
C13 100n C-EU050-025X075 C050-025X075 resistor
C21 100n C-EU050-025X075 C050-025X075 resistor
C23 100n C-EU050-025X075 C050-025X075 resistor
C24 100n C-EU050-025X075 C050-025X075 resistor
C33 100n C-EU050-025X075 C050-025X075 resistor
N. 1 condensatore elettrolitico 25VDC 100u passo 2.5 (Distrelec: 801844)
C14 100u CPOL-EUE2.5-6 E2,5-6 resistor
N. 2 condensatori elettrolitici 25VDC 2200u passo 7.5 diametro 16 H20 (RS: 711-1176)
C1 2200u CPOL-EUE7.5-16 E7,5-16 resistor
C2 2200u CPOL-EUE7.5-16 E7,5-16 resistor
N. 2 condensatori elettrolitici 16VDC 220u passo 2.5 (Distrelec: 801796)
C18 220u CPOL-EUE2.5-6 E2,5-6 resistor
C58 220u CPOL-EUE2.5-6 E2,5-6 resistor
C34 ponticello
C35 ponticello
N. 2 condensatori ceramici 470p passo 5 (Distrelec: 833019)
C20 470p C-EU050-024X044 C050-024X044 resistor
C32 470p C-EU050-024X044 C050-024X044 resistor
N. 4 condensatori elettrolitici 35V 470u passo 5 diametro 10 (Distrelec: 801191)
C3 470u CPOL-EUE5-10.5 E5-10,5 resistor
C5 470u CPOL-EUE5-10.5 E5-10,5 resistor
C7 470u CPOL-EUE5-10.5 E5-10,5 resistor
C11 470u CPOL-EUE5-10.5 E5-10,5 resistor
N. 2 condensatori elettrolitici 10V 470u passo 2.5 diametro 6 (Distrelec: 818559)
C8 470u CPOL-EUE2.5-6 E2,5-6 resistor
C25 470u CPOL-EUE2.5-6 E2,5-6 resistor
N. 2 condensatori polipropilene 63VDC 4n7 passo 5 (Distrelec: 828227)
C19 4n7 C-EU050-025X075 C050-025X075 resistor
C31 4n7 C-EU050-025X075 C050-025X075 resistor
N. 1 condensatore elettrolitico 16VDC 4u7 passo 2 diametro 5 (Distrelec: 803581)
C43 4u7 CPOL-EUE2-5 E2-5 resistor
N. 4 diodi zener 0.5W 20V (Distrelec: 600786)
D1 20V ZENER-DIODEZD-1 0 ZDIO-10 diode
D3 20V ZENER-DIODEZD-1 0 ZDIO-10 diode
D5 20V ZENER-DIODEZD-1 0 ZDIO-10 diode
D7 20V ZENER-DIODEZD-1 0 ZDIO-10 diode
N. 1 diodo zener 0.5W 27V (Distrelec: 600789)
D16 27V ZENER-DIODEZD-1 0 ZDIO-10 diode
N. 4 diodi zener 0.5W 10V (Distrelec: 600779)
D2 10V ZENER-DIODEZD-1 0 ZDIO-10 diode
D4 10V ZENER-DIODEZD-1 0 ZDIO-10 diode
D6 10V ZENER-DIODEZD-1 0 ZDIO-10 diode
D8 10V ZENER-DIODEZD-1 0 ZDIO-10 diode
N. 2 diodi zener 0.5W 3V9 (Distrelec: 600769)
D9 3V9 BZV10 DO34Z7 diode
D14 3V9 BZV10 DO34Z7 diode
N. 5 diodi 1N4148 (Distrelec: 603016)
D10 4148 DIODE-D-5 D-5 diode
D11 4148 DIODE-D-5 D-5 diode
D12 4148 DIODE-D-5 D-5 diode
D15 4148 DIODE-D-5 D-5 diode
N. 2 diodi led rossi 1.8mm 1.7Vf (Distrelec: 633108)
LED1 1V7 LED3MM LED3MM led
LED3 1V7 LED3MM LED3MM led
N. 2 transistor 2SA970BL (Distrelec: 605029)
Q1 2SA970BL -PNP-TO92-ECB TO92-ECB transistor-ne
Q9 2SA970BL -PNP-TO92-ECB TO92-ECB transistor-ne
N. 4 transistor darlington NTE48 (Distrelec: 668216)
Q10 NTE48 -NPN-TO92-EBC TO92-EBC transistor-ne
Q11 NTE48 -NPN-TO92-EBC TO92-EBC transistor-ne
Q12 NTE48 -NPN-TO92-EBC TO92-EBC transistor-ne
Q18 NTE48 -NPN-TO92-EBC TO92-EBC transistor-ne
NOTA: In sostituzione degli NTE48, si possono usare i BC517, con l'accortezza di montarli al contrario rispetto a quanto disegnato sulla board (i pin sono CBE invece di EBC).
N. 4 transistor BC550C (Distrelec: 610366)
Q6 BC550C BC550C TO92-EBC@1 transistor-np
Q8 BC550C BC550C TO92-EBC@1 transistor-np
Q19 BC550C BC550C TO92-EBC@1 transistor-np
Q28 BC550C BC550C TO92-EBC@1 transistor-np
N. 6 transistor BC560C (Distrelec: 610374)
Q2 BC560C BC560C TO92-EBC transistor-pn
Q3 BC560C BC560C TO92-EBC transistor-pn
Q4 BC560C BC560C TO92-EBC transistor-pn
Q5 BC560C BC560C TO92-EBC transistor-pn
Q7 BC560C BC560C TO92-EBC transistor-pn
Q23 BC560C BC560C TO92-EBC transistor-pn
N. 10 transistor 2SD882 (RS: 686-8045)
T9 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T10 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T11 2SD882 2SD882 TO126V transistor-np
T16 2SD882 2SD882 TO126V transistor-np
T17 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T18 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T2 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T3 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T7 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
T8 2SD882 TO126-ECB-BOTTO M TO126-BOTTOM transistor-np
N. 4 transistor 2SB772 (RS: 686-8041)
T1 2SB772 TO126-EBC-BOTTO M TO126-BOTTOM transistor-pn
T4 2SB772 TO126-EBC-BOTTO M TO126-BOTTOM transistor-pn
T5 2SB772 TO126-EBC-BOTTO M TO126-BOTTOM transistor-pn
T6 2SB772 TO126-EBC-BOTTO M TO126-BOTTOM transistor-pn
N. 2 integrati stabilizzatori 78L12 (Distrelec: 647079)
IC3 78L12 78LXX 78LXX v-reg
IC5 78L12 78LXX 78LXX v-reg
N. 1 integrato logico 40106 (Distrelec: 646108)
IC4 40106N 40106N DIL14 40xx
N. 1 integrato logico HEF4013 (Distrelec: 648788)
N. 2 zoccoletti DIL14 (Distrlec: 650555)
N. 1 operazionale OPA604 (Distrelec: 641444)
IC1 OPA604 OPAMP SINGLE DIL08 linear
N. 2 operazionali OPA2604 (Distrelec: 641446)
U1 OPA2604 OPAMP DUAL DIL08 linear
U2 OPA2604 OPAMP DUAL DIL08 linear
N. 3 zoccoletti DIL8 (Distrelec: 650554)
N. 2 rele' 12V 10mA A-12-WK (Distrelec: 400022)
N. 5 connettori molex 2 pin (Distrelec: 114620)
N. 5 prese molex 2 pin (Distrelec: 114600)
N. 4 connettori molex 3 pin (Distrelec: 114622)
X3 22-23-2031 22-23-2031 22-23-2031 con-molex
X7 22-23-2031 22-23-2031 22-23-2031 con-molex
X8 22-23-2031 22-23-2031 22-23-2031 con-molex
X9 22-23-2031 22-23-2031 22-23-2031 con-molex
N. 4 prese molex 3 pin (Distrlec: 114602)
N. 22 contatti molex (Distrelec: 127661)
N. 12 dissipatori AAVID ML33 8.5°C/W (RS: 712-4263)
NOTA: In alternativa si possono usare i Fischer SK126/37.5/SA220, più comodi per via della filettatura M3, ma più rari e più costosi (Distrelec: 652883)
N. 12 rondelle acciaio zincato M3 diametro esterno 7 mm (Distrelec: 348259)
NOTA: necessarie solo per i dissipatori AAVID ML33
N. 12 dadi esagonali M3 (Distrelec: 348280)
NOTA: necessari solo se si usano come dissipatori gli ML33 o il coperchio di fondo
N. 12 viti M3 torx 12mm (Distrelec: 343195)
N. 12 rondelle elastiche M3 acciaio (Distrelec: 348268)
NOTA: non servono se si usa il coperchio di fondo come dissipatore.
PCB
PART LIST
R72 ponticello
R73 ponticello
NOTA: chi utilizza il coperchio di fondo come dissipatore, può portare la corrente di riposo a 180 mA, in tal caso R2, R6, R11 e R21 dovranno essere almeno da 2 W.
N. 4 resistenze a filo 4W 15R passo 13 (Distrelec: 721215)
R2 15 4W resistor
R6 15 4W resistor
R11 15 4W resistor
R21 15 4W resistor
NOTA: chi utilizza il coperchio di fondo come dissipatore, può portare la corrente di riposo a 150 mA, in tal caso R16 e R46 dovranno essere da 470 ohm.N. 2 resistenze 0.4W 470R passo 5 (Distrelec: 714302)
R16 470 0.4W resistor
R46 470 0.4W resistor
Aggiornamento: ignorare questa nota. Il valore di R16 e R46 deve essere di 3.3Kohm.
NOTA: chi utilizza il coperchio di fondo come dissipatore, può portare la corrente di riposo a 150 mA, in tal caso R1, R5, R7 e R10 dovranno essere da 39 ohm e da almeno 5 W, e R23 R51 da 6R8.
N. 4 resistenze a filo 7W 39R passo 20 (Distrelec:721138)
R1 39 7W resistor
R5 39 7W resistor
R7 39 7W resistor
R10 39 7W resistor
NOTA: chi utilizza il coperchio di fondo come dissipatore, può portare la corrente di riposo a 150 mA, in tal caso R21 e R51 dovranno essere da6.8 ohm4.7 ohm.
N. 2 resistenze 0.4W 4R7 passo 5 (Distrelec: 714259)
R23 4R7 R-EU_0204/5 0204/5 resistor
R51 4R7 R-EU_0204/5 0204/5 resistor
NOTA: NON SALDARE SUBITO QUESTA RESISTENZA. Leggere le note relative a questa resistenza (e allo zener D16) nei post successivi.
NOTA: Sarebbe meglio portare il valore di C14 a 470 uF. Con tale valore, l'inserzione del relè avviene con un ritardo maggiore, e da il tempo alle valvole di scaldarsi quando si accende l'ampli. Mantenendo il valore originale il circuito funziona lo stesso, ma può accadere che durante la fase di accensione il relè attacchi-stacchi un paio di volte prima di rimanere stabile nella condizione di normale funzionamento. Per il valore e la tensione che serve a noi non ci sono condensatori con passo da 2.5, per cui occorre prenderne uno con passo 5 e sagomarne i terminali per adattarli al passo 2.5 previsto sulla pcb.
N. 1 condensatore elettrolitico 35VDC 470u passo 5 (Distrelec: 802595)
C14 470u CPOL-EUE5-10.5 E5-10.5 resistor
NOTA: per coloro che hanno intenzione di usare il cabinet slim da 40 mm di altezza, questi condensatori è possibile utilizzarli soltanto se si montano sulla board i dissipatori Fischer SK126 (gli AAVID ML33 sono troppo alti) oppure se si utilizza il coperchio di fondo come dissipatore. Ho tolto l'indicazione "facoltativi" in quanto è preferibile montarli per migliorare la stabilità del ramo di tensione positivo (in alcuni casi può verificarsi l'attivazione della protezione senza alcun motivo apparente).
C34 ponticello
C35 ponticello
NOTA: Per il montaggio di questo diodo leggere le note nei post seguenti dedicati allo zener D16 e alla resistenza R33.
ATTENZIONE: gli AAVID ML33 non consentono l'utilizzo di un cabinet slim da 40 mm di altezza. Chi vuole utilizzare un cabinet slim deve necessariamente procurarsi i Fischer SK126/37.5/SA220 oppure usare il coperchio di fondo come dissipatore.
PER CHI UTILIZZERA' IL COPERCHIO DI FONDO COME DISSIPATORE
NOTA: per dissipare il calore si può utilizzare il coperchio di fondo, purchè sia di alluminio, di almeno 2 mm. di spessore, e con una superficie minima di 300 x 200 mm. In tal caso, i 12 dissipatori (ML33/SK126) non sono necessari. Invece è necessario prendere delle rondelle termoconduttive isolanti:
N. 12 rondelle termoconduttive isolanti (Distrelec: 652448)
Re: Tutto quello che serve per costruirsi un Lightning
Dom 2 Dic 2012 - 18:24
Relativamente alla power board e alle resistenze R70 e R71
Il problema riguarda solo l'uscita PRE-OUT, per cui chi non userà tale uscita può tranquillamente ignorare tutta la questione.
Per una svista durante la fase di disegno, l'uscita PRE-OUT è stata collegata prima del rele' di protezione, e non dopo come avrebbe dovuto essere. L'uscita funziona lo stesso, il problema è che in questo modo non vi è alcuna protezione anti-bump, per cui qualora si dovesse accendere il Lightning e il finale è già acceso, si potrebbe avere sui diffusori un violento transiente di accensione.
Per risolvere il problema, le resistenze R70 e R71 devono essere montate in questo modo:
R72 e R73 sono dei ponticelli, come già indicato nella part list.
R70 e R71 andranno collegate con un capo alla piazzola che avrebbero dovuto occupare normalmente (quella collegata al connettore X8 pre-out) e l'altro capo invece al ponticello di R72/R73. La foto è abbastanza esplicativa, ma se dovessero esserci dubbi non esitate a chiedere.
CONSIGLIO
Sab 8 Dic 2012 - 12:34
CONSIGLIO
Subito prima di iniziare ad assemblare una delle schede, stampatevi la part list relativa da questo thread: potrebbe esserci stata una variazione/correzione, che magari nella copia che avevate stampato in precedenza non compare.
Dom 16 Dic 2012 - 12:22
Aggiornata la part list tenendo conto dei dissipatori AAVID ML33 come alternativa ai rari e più costosi Fischer SK126/37.5/SA220.
Dom 16 Dic 2012 - 13:48
Aggiornata la part list relativa alla power board che ora prevede l'aumento della corrente di riposo a 180 mA (privilegio consentito solo a coloro che useranno il coperchio di fondo come dissipatore).
Ricordo che nel caso si decida di usare il pannello inferiore del cabinet come dissipatore, è necessario che questo sia di alluminio, di almeno 2 mm di spessore e di superficie non inferiore a 300 x 200 mm.
Dom 16 Dic 2012 - 15:57
Aggiornata la part list per l'affinamento del valore del condensatore C14 della power board nel circuito di protezione a relè.
Lun 17 Dic 2012 - 1:04
Aggiornata la part list per nota informativa sui condensatori C1 e C2 della power board.
Lun 17 Dic 2012 - 12:47
Aggiornata la part list della power board per nota informativa sui dissipatori AAVID ML33.
Dom 23 Dic 2012 - 23:04
Aggiornate le part list della power board e della preamp board, per nota informativa relativa alle resistenze di potenza superiore a 0.6 Watt.
Transiente allo spegnimento
Ven 28 Dic 2012 - 23:15
MODIFICA PER ELIMINARE IL TRANSIENTE ALLO SPEGNIMENTO DELL'AMPLIFICATORE
Una cosa che ho notato questi giorni, e a cui non avevo fatto caso prima, è il transiente allo spegnimento: se si spegne l'amplificatore e la cuffia è ancora attaccata, oppure il finale - collegato all'uscita pre-out - è ancora acceso, la "botta" può risultare fastidiosa, per cui ho cercato di trovare una soluzione il più possibile elegante in modo da eliminare - o quanto meno attenuare - il problema. E per fortuna una soluzione c'è, ed è anche semplice.
Il transiente allo spegnimento era causato dalla repentina caduta della tensione di alimentazione sui finali di uscita. Tale caduta era abbastanza veloce da eludere anche l'elettronica di protezione che comanda il rele'. L'unico modo quindi per evitare il transiente era quello di rallentare tale caduta di tensione, oppure velocizzare la caduta sul circuito del rele'. Quest'ultima soluzione era quella più facilmente praticabile, per cui è quella che ho adottato. In sostanza, quando si spegne, la tensione di alimentazione comincia a scendere, ma con la modifica è il rele' a spegnersi prima che i finali abbiano il tempo di generare il transiente.
Qui sopra vedete la foto della modifica che mostra chiaramente l'intervento da effettuare.
1) Se l'avete già saldata, dovrete eliminare la R33 (usando le tronchesine, vi sconsiglio di procedere con la dissaldatura);
2) prendete come riferimento la scritta "121113v2A" sullo stampato, quindi grattate via un po' di solder isolante dalla pista che porta il ramo positivo di alimentazione, nel punto che vedete nella foto;
3) saldate lo zener da 27 V con il catodo rivolto verso il positivo di alimentazione, come in foto;
4) saldate la resistenza R33 sullo stampato nel foro verso R72, e l'altro capo lo salderete al terminale dello zener rimasto libero.
La R33 e lo zener D16 sono quindi collegati in serie verso il ramo positivo di alimentazione da 40 Volt.
Fate attenzione a quanto segue:
- controllate che il diodo zener sia funzionante prima di utilizzarlo (usate il provadiodi del tester);
- controllate che il verso del diodo sia quello giusto.
Se il diodo è guasto ed è in cortocircuito, nel momento in cui dovrà scattare il rele' questo si brucerà.
Se il diodo è montato a rovescio, il rele' si brucerà.
Fate attenzione, quindi.
R33 = 100 ohm, 0.4 Watt
D16 = zener 27 V, 0.5 Watt
Ven 28 Dic 2012 - 23:20
Modificati lo schema elettrico e la part list della POWER BOARD per l'aggiornamento relativo al transiente di spegnimento.
Gio 31 Gen 2013 - 0:10
Modificato lo schema elettrico e la part list della preamp board. La modifica consiste nella variazione del valore dei due condensatori C3 e C7 di accoppiamento, portati a 68nF (prima erano da 10nF), e delle due resistenze R6 e R16 portate a 51K (prima erano da 100K).
La modifica migliora leggermente le caratteristiche di rumore dell'ampli, e amplia la banda passante in basso.
Chi ha già montato la scheda può scegliere di applicare la modifica o meno, si tratta solo di una rifinitura.
Gio 31 Gen 2013 - 0:20
Modificato lo schema elettrico e la part list della power board, per la variazione del valore di R63, prima da 220K e ora portato a 100K.
Tale modifica è necessaria se l'ampli dovesse andare in protezione senza motivo (ad esempio per via di un brano ricco di basse frequenze).
Gio 31 Gen 2013 - 14:49
bandAlex ha scritto:Modificato lo schema elettrico e la part list della preamp board. La modifica consiste nella variazione del valore dei due condensatori C3 e C7 di accoppiamento, portati a 68nF (prima erano da 10nF), e delle due resistenze R6 e R16 portate a 51K (prima erano da 100K).
Per le resistenze e' possibile, come mi hai insegnato, cambiarle saldandole da sopra; per i condensatori come si fa, visto che dall'altra parte dovrebbe esserci lo zoccolo della valvola ed inoltre i piedini sono 'sotto' al corpo del condensatore stesso?
Gio 31 Gen 2013 - 14:58
Posso dirti come ho fatto io: ho staccato i due condensatori inclinandoli più volte a destra e sinistra (a un certo punto il rame dei terminali cede). Poi ho saldato quelli nuovi da sopra, lasciano i terminali un po' lunghi. Non è esteticamente un granchè, ma funziona.
Gio 21 Feb 2013 - 21:26
Aggiornata la part list della power board per la sostituzione delle rondelle isolanti termoconduttive adesive con altre in ossido di alluminio (quelle autoadesive non garantisco un buon isolamento).
Dom 3 Mar 2013 - 17:29
Modificati lo schema elettrico e la part list della preamp board. La modifica consiste nella variazione del valore di R21 e R25, da 330 ohm a 100 ohm. La modifica è obbligatoria, in quanto il valore attuale di R21 e R25 è errato e può portare all'intervento della protezione anche per brevi e modesti abbassamenti della rete elettrica. Questa variazione va fatta insieme a quella della supply board descritta nel post che segue.
Dom 3 Mar 2013 - 17:47
Modificati lo schema elettrico e la part list della supply board. La modifica consiste nella variazione del valore della resistenza R6, da 100 ohm a 47 ohm.
Dom 3 Mar 2013 - 18:18
Aggiornati lo schema elettrico e la part list della power board. La modifica consiste nella variazione dei valori delle resistenze R7, R5, R1, R10 nel caso si utilizzi il pannello di fondo come dissipatore. Il valore è stato portato a 39 ohm, in modo da alleggerire il peso sostenuto dagli shunt (leggi: abbassare leggermente le temperature). Per lo stesso motivo la corrente di riposo è stata portata 150 mA, e il valore di R23 e R51 alzato a 6.8 ohm.
Nel mio esemplare, con i nuovi valori indicati sopra e con il pannello di fondo che fa da dissipatore, con il coperchio completamente traforato in alluminio (ricordo che si tratta dello slim line della hifi2000, alto 40 mm e profondo 350) le temperature raggiungono valori abbastanza elevati, per cui si consiglia la massima attenzione nell'eseguire il cablaggio in modo da favorire il più possibile la circolazione dell'aria all'interno.
Questo sarà l'ultimo intervento di tipo elettrico sul Lightning. Beh, quasi l'ultimo. Da questo momento in poi ci occuperemo solo di meccanica e...
Preamp BOARD: modifica al circuito dei filamenti
Ven 5 Apr 2013 - 0:34
Per eliminare una lunga pista che avrebbe attraversato quasi l'intera pcb, quella di collegamento tra i due filamenti in serie, a suo tempo mi venne la splendida idea di sfruttare a tale scopo il piano di massa. Ciò era possibile perchè le due alimentazioni (anodica e filamenti) sono del tutto separate tra loro. In realtà poi questa scelta si è rivelata un grosso errore, e ora eccomi qui a porre rimedio.
Chi ha già assemblato la scheda dovrà dissaldare il piedino 5 di ciascuno zoccolo, oppure tagliarlo a filo della pcb, in modo che piegandolo all'insù sia poi possibile saldarci un filo. Una volta che i piedini sono entrambi separati dal piano di massa e liberi, collegarli tra loro tramite un pezzo di filo isolato.
Nelle foto che seguono si vede l'intervento effettuato su una pcb in fase di assemblaggio.
Chi deve fare la modifica? Consiglio a tutti di farla, perchè essa elimina un leggero hum di fondo, anche se questo si sente solo con le cuffie a bassa impedenza.
Mar 2 Lug 2013 - 0:57
Aggiornamento per quanto riguarda la POWER BOARD: R16 e R46, R23 e R51.
Leggere le note corrispondenti nella part-list.
Mar 26 Nov 2013 - 0:16
Modificata la part-list della preamp board, per la modifica relativa all'accoppiamento in continua dei triodi (eliminazione dei condensatori C3 e C7).
